in my SGY present firmware version is...
baseband v. S5360DDLA2
Build no. GINGERBREAD.DDLA3
my galaxy y is rooted..
i tried to update via phone & downloaded the latest firmware but after reboot it got struck in 26%
i tried this five times but every time the same result.....!
i tried via kies but the option upgrade firmware is got hide ......!
please help me....!!!!
thanks in advance..
DONT USE KIES!!
TRY TO FLASH FIRMWARE USING ODIN!!
TRY AND TESTED !!
THIS METHOD JUST TAKES 1MINUTE!!
firmware is the basic need of a phone,without it phone will not work.!!
if you want to flash ur phone in less than 2 min.just use ODIN 1.84(flashing back to stock firmware)
as of mine,i have DDLA1 firmware.
requirements:
-SAMSUNG USB DRIVER TOOLS INSTALLER
-ODIN 1.84
-AND THE FIRMWARE YOU DOWNLOADED
(THE FIRMWARE FOLDER IS ABOUT 150MB)
DOWNLOAD THIS FILES ON GOOGLE,JUST SEARCH AND READ
STEPS:
(CLOSE KIES)
1.INSTALL SAMSUNG USB DRIVERS(VERY IMPORATNT)
2.TURN OFF YOUR CP
3.GO TO DOWNLOAD MODE (PRESS VOLUME DOWN KEY,HOME KEY,AND POWER BUTTON KEY)
4.PRESS VOLUME UP TO CONTINUE
(DONT CONNECT IT TO COMPUTER)
5.OPEN ODIN 1.84
AS YOU CAN SEE,THE FIELDS ARE PIT.BOOTLOADER,PDA.PHONE.CSC
6.CLICK PIT,CLICK BROWSE,FIN THE FOLDER OF THE FIRMWARE.
7.select totoro_0623.pit(just a sample,this is my firmware DDLA1)
8.follow this steps:
bootloader.pda.phone.csc. section(dont check it because it will be automatically checked)
bootloader:BOOT_S5360DDLA1_REV05.tar
pda
DA_S5360DDLA1_REV05.tar
phone:MODEM_S5360DDLA1_REV05.tar
csc:GT-S5360-MULTI-CSC-ODDLA1.tar
9.check Re-partition on the upperleft..
leave uncheck the "FLASH LOCK,PHONE EFS CLEAR,PHONE BOOTLOADER UPDATE"
10.CONNECT YOR PHONE TO PC.
IN THE "id COM" section you must see the word "ADDED"(you must install the samsung drivers)
after that..click start..
it will process.(about 30 seconds)
after that proccessing you will see the word "PASS"
dont remove the connection wait until it booted up to the home screen.
after that,you may remove the connection..
enjoy!!
tested and proven by me!!
there is no pay for this tutorial!!
JUST HIT THANKS!!
