Shape Fun
I am trying to compile a database of barcodes for an upcoming app that I plan to work on. If anyone who has an Android device can go to the link and download the app to your device that would be great. All you have to do is every time you go shopping or you are by a barcode just scan it with the app or enter it manually and insert some details about the product, then just click "Add product" and it will be sent to my database. There is a known issue with the app, where when you hit the button it seems that nothing happened, but believe me IT DID GET SENT! There is some issue with the threading that I need to fix that is not allowing my dialog box to come up. Obviously there are some problems with it, but it does what I need it to do which is add barcodes! I just wanted to get in on the market so that I can start getting a lot of barcodes added and so people can easily receive updates to the app.
If it is not available in your country, it should be soon, just updated my listing to include all countries!
Play Link
XfmmKlCoHBkukslQOl7W4YPy0_lOlBN9BO_nJsRxUPRkYQkeWvmGg9MxcAgbIHd8ng
