So many ways to share, so wondering what works best and limitations of each...
I want to share Photos, Music and Videos from my SG3 to a friends phone. Used the S-Beam other day do it and it worked fine.
But then I also see Wifi Direct and Bluetooth Share, just wondering what is the difference.
What I understand is S-Beam uses the NFC chip. Wifi direct...likely uses the Wifi antenna and Bluetooth uses Bluetooth.
I am assuming using NFC is the fastest, but I have to read how to use it exactly...meaning, do I have to be playing that file and then touch the phone "each time" to see the "Touch to beam" option or you touch once and then they are paired. The later is what I thought how it works, but then I don't see the touch to beam option again unless the two phones are touched.
I have not tried to see if entire folders with music and videos can be sent...
I find the "Hey I just shared my Playlist" in the iPhone bashing advt. little useless. If you don't have the same songs on both phone's what is the point of transferring the Playlist as that is just an index of your favourite songs, but not the song files themselves.
