Shinjitsu Rom For ZTE Warp
Status
Not open for further replies.
shinru2004
Android Expert
Recognized Developer
Thank you to xBabyfaceKingx, Bocephus87, Hroark13, mercury0x000d, and cartersball for your donation and support!
A special thanks to Quoros for your donation of a new Warp! Thank you
ROM Features
  • Init.d support
  • Build.prop Tweaks
  • Auto DB Defrag
  • Loopy Smoothness
  • Various CPU Tweaks and System Tweaks
  • Deodexed
  • Themed
  • Reboot Options
  • Optimized
  • SD Booster Script
  • a2sd full support
  • Over-clocked kernel (optional)
  • Dalvik-JIT Enabled
  • Custom wallpapers
  • All Bloatware Removed
  • Swipe to clear Notifications (Credits to hansip87 @ XDA)
Removed Apps
Alarming.apk (Replaced with AOSP Desk Clock)
Camera.apk (Replaced with MIUI Camera)
Email.apk
Filer.apk (Replaced with MIUI File Explorer)
GenieWidget.apk
GoogleQuickSearchBox.apk
MagicSmokeWallpapers.apk
Maps.apk
Music.apk (Replaced with Google Play Music)
SoundRecorder.apk
Sprint_InstallerNC_2100.apk
SprintPermissions.apk
Stopwatch.apk
Street.apk
TaskManager.apk
VisualizationWallpapers.apk
VoiceDialer.apk
VoiceSearch.apk
VpnServices.apk
YouTube.apk
Some Screen Shots
Found the correct permissions for the flash-able zip, symlinks and permission's on this rom are different from stock. All future releases will be flashed.
Boot animations
Shinjitsu Warped
Shinjitsu After Effects
Ringtones
If you would like to use your own custom mp3 ringtone's, make a folder on the root of your sdcard named "Ringtones" without quotation. Place any MP3's you might want to use as a ringtone into this folder. they can then be selected in the ringtone menu.
Code:
Changelog
Versions before 1.5 will no longer be supported
*To Do
Make more Awesomeness, Donations appreciated.
Version 1.5.1c Beta 4
-Added Official Jellybean Google Play Music port
Themed system menu to resemble ICS.
More theme fixes.
More Build.prop edits for GPU performance.
Version 1.5.1c Beta 3
-Added Timescape, and all framework files. (Removed)
Themed Xperia Launcher (Might remove for Holo Launcher)
Added Dev tools
Added Xloud sound drivers
Removed A2sd and all scripts (Dalvik JIT still enabled)
added Chrome port (Removed stock browser)
Ported Notification Toggles (Credits to lidroid @XDA)
Added Swipe to clear notifications
Complete re-theme and new layout for all system menus
Themed the lockscreen
Added Jellybean system font
SRWallpapers updated with ICS and jellybean wallpapers
New kernel with swap support (Credits to Downthemachine)
Intermediate Update 1
Fixed text colors
Changed status bar color
Added custom splash screen
Version 1.5.1c
Added Experia S HD Home Launcher
Added all Compatible Experia S Widgets
Thanks to Hroark13 for his work on the source code
Thanks to me for Overclock :D
Overclock to 1.7Ghz (Default is 1Ghz)
Added QuickPic (Removed Gallery3D)
Removed ADW Launcher
Fully Implemented a2sd & a2sd GUI
Dalvik JIT enabled
Dalvik-Cache moved to sdcard when sd-ext is present
New CM7 EGL drivers, we lose 10fps but gain [B]stability[/B]
Added Live wallpapers back
Added Experia S live wallpaper
Removed Miui Camera (Added ICS+ Camera)
Switched back to SuperUser app + Binary
Newer Kernel, Should fix signal issues
Ported LunarUI from CM7 for HTC to Shinjitsu Rom
Major UI Overhaul
Camera Issues have been fixed
Version 1.5b
Added CM7 compiled ADW Launcher (Better compatibility)
Removed Beats audio from test version (Caused Camera not to function)
Added Custom Shinjitsu boot Animation
Removed Miui File Explorer (Replaced with lighter CM7 File Explorer)
Changed Default Background
Removed stock gallery (AOSP Gallery3d to fix issues experienced by users)
Removed EXT4 tuning script (Causing issues with permissions, should fix GPS and WiFi location access)
Ported CMwallpapers for shinjitsu rom
Added jBrd400's fix for CWM data backup
Added new Adreno 205 libraries (Basemark stock score 12, new score 16.52)
Version 1.1c
Added apps2sd support in init.d
Added DSPManager from CM7
Removed more stock apps and un-needed services
Added AOSP Gingerbread launcher (Lightweight)
Added Miui File Explorer (Lightweight)
Added Miui Camera to replace stock app (Lightweight)
Version 1.1b
ICS Spectrum Live Wallpaper
System Integrated Spare Parts app from AOSP
Reboot, Reboot Recovery, Reboot Bootloader added to power menu
CRT On/Off animation
Removed more Bloatware
Enabled Init.d Support
Added numerous Scripts for optimization
Version 1.0
Initial Release
Deodexed
Themed
Optimized System apps
Removed some bloatware
Added ICS Style GOLauncher
Added Google Play Music
Updated market to Google Play
Changed boot Animation
WARNING
I am not responsible for any damages to your device, You have been warned
Step 1. Download
Step 2. extract to your sdcard in clockworkmod/backup or root of sdcard for zip
Step 3. Reboot to recovery
Step 4. Make a Nandroid backup (Just in case)
Step 5. do a factory/data reset
Step 6. clear cache
Step 7. Advanced -> clear dalvik-cache
step 8. restore or install zip from sdcard
Step 9. Enjoy the silky smoothness of Shinjitsu Rom
The first boot will take a while as the system rebuilds the new dalvik-cache, Each restart afterwards will take half the time of stock
Download Links
Shinjitsu Rom 1.5.1c Beta-3
Shinjitsu Rom Intermediate Update-1.zip
Shinjitsu Rom 1.5.1c-Beta2.zip
Shinjitsu Rom 1.5.1c.zip
Shinjitsu Rom 1.5b
No Longer supported
Shinjitsu Rom 1.1c
Shinjitsu Rom 1.1b
Shinjitsu Rom 1.0b
I rooted this device. Decided to try out a few of the custom ROMs available. I tried this one following the instructions, nothing but some broken rainbows. When the phone usually boots I get android splash and then boost splash screens then it vibrates once quickly and then the lock screen is there. It immediately vibrates and then shows some rainbows in the grey, red, white and black colors. Let it set for 30 min, still nothing. Is there a tool like Odin that I can use to completely re-flash a backup or stock image?
N861
CWM Recovery Touch v6.xx
This Rom is for the n860 if you made it to the lockscreen consider yourself lucky. If you have the n860. OG ZTE Warp then this Rom will work for you. Otherwise check the warp sequent all things root section.
Status
