Help short battery time
  • Thread starter Thread starter Battery problems
  • Start date Start date
B
Battery problems
Guest
I have a Samsung s5 and have done all the recent updates, lollipop, and my battery is so bad since then. It won't go a whole day with hardly any use. Any ideas
A factory reset, or at least booting into recovery to clear the cache partition is recommended after taking any OTA Update.
If you need to backup before hand, take a look at something like Helium. :)
I use two ancient on/off widgets, one for mobile data, one for wifi data. I keep them off whenever I can to help the battery last a few days. The former is called Connection Manager but is apparently deceased, the latter is WiFi Connection Manager. I'm not on Lollipop. but that shouldn't matter.
