Shortcut to a Setting
winky
Member
Is there a way to create a shortcut to a specific setting? For example, can I create an icon on my home screen that, when tapped, will take me straight to the Screen timeout settings screen or the Wi-Fi settings screen?
Thanks! Unfortunately, the specific shortcut I want is not on the list and I have no idea how to create one. Do you?
I want to create a shortcut that takes me directly to the Screen timeout settings.
Maybe not exactly what you're looking for, but if you click on my battery meter widget it lets you pick the screen timeout setting.
Search 'battery widget' and it's the black + white one by Start Technology Inc.
