Sorry, should have mentioned that.What device are you using?
... Thom
Thanks for replying
I was just wondering if it should continue to run when I did not have wifi or data connection on.
So this is the same for the email app, as that continues to run when wifi/data is not on.
1 process 1 service is running for both even when wifi/data is not on.
I just want to know that this how the Android OS operates and there is nothing to worry about.
Thanks for the detailed reply.In general, yes, services and apps will "run" in the background whether you are connected to a network and sometimes if you haven't even used an app recently. This is normal for Android (being, basically, Linux) and you can mostly leave it alone to manage those things. Android will most times do a better job than you will.
You only get concerned if something shows up when you tap battery as using a large percent of battery that is out of proportion. That usually means there may be a background sync or some such you would profit from unchecking in accounts or some other app setting.
