Root Should I go to cyanogenmod
no idea how you'd do it, yet i'm sure it shouldn't be that hard to root, then unlock bootloader, then install a custom recovery, and flash the rom. are you sure xda doesn't have threads that touch on these points? usually they do.
that said, my lg optimus G, which runs cm11, simply flies. easily on par with my moto x. never a stutter or lag.
There arent instructions on the recovery, but the rest I know how to do.
Would it be worth loosing my front camera to get Cyan 11?
All depends if you do video calls, such as Skype, or you like taking selfies I think. :)
FWIW I do use CM11, but on an Oppo Find 7a and everything works here. and is far better than the manufacturer's firmware.
Thread moved to the LG L90 - All Things Root Forum, for better exposure/help and since topic is root related.
I flashed all files properly last night on my lg l90 d415 and there are a lot more probs than we are told. I'm stuck with it until I figure out why it won't recognize my external sdcard. Can't flash w/o that.
Did you use the one for the d415 made by shinobisoft? I've had no issues at all since flashing any ROMs
and here is nightly cm12 5.0.2 every thing works is made for lg l90 d415: DevolutDev posted it go and donate to him
if u have bricked lg go to this website and flash the kdz: http://lg-firmware-rom.com/
or you can go and flash rom that is customized .. btw it comes pre rooted
and de bloat like tmobile stock aps.... are removed: chrome://mega/content/secure.html#!WM90EQoY!4KPmDcC095MYoZ6wk2epeQ10iLsdQCntB2ETkXGvcEw
and thats it thanks
and thats it thanks
Thanks for that. Here is a link to my thread http://androidforums.com/threads/installing-cm11-cm12-pac-on-the-l90-d415.896630/
It hapents becouse cyanogen mod developers made roms for w7 but there is d415-d405-d410 wersions that are w7 sooo yeah i think some one should say that to them or something
Well now developers have made the roms universal. Some roms work on all versions of the l90 now
I have one issue on my cm12 nightly my video Recording aint work it saids thats Recording but not
Thats an issue with most D415 users. All D415 roms have no video recording. Some will act like it is recording but it will not save a file.
Sorry about this issue, and it is being worked on
