Sorry if this has been talked about somewhere, but with ICS coming out today or this weekend, is it a good idea to do a factory reset? Or should you upgrade first and play around with it and then do a factory reset? I know when I first got my phone I just downloaded all kinds of apps and kept tweaking the settings, then did a factory reset and put it back to the way I wanted. If you do a factory reset after installing ICS, will it reset it with the original operating system, or does it reset it with ICS? I am just wondering what most people recommend.
