Side Panel?
olbriar
Moderator
I utilize the side panel on my Note 10+ for quick access apps, calendar, notes, contacts etc. It is a feature that I enjoy. I am curious if the panel was on the S20 and S21? I hope that it is and that they did away with the bixby joke.
Added: I just watched a review that answered both of my questions. The side panel comes on the S21 Ultra as well as bixby. I remapped the bixby button on my note and I will definitely be doing the same if I purchase.
you should hold out and see what comes out for the next note phone.....just saying
My Note has served me well. I have zero complaints about it. However, I just don't use the S pen. I played with it some at first. I even tried to incorporate it into my daily use. I'm sure it's handy and has many useful functions but it has been over half a year since it was last removed from the phone. It's just not me. If I buy the S21 Ultra I will not be purchasing a S pen to use with it. Nothing against those that enjoy the pen. And as for specs... if there is a Note 21, and I suspect there will be, I'm guessing the specs to be similar to the S series as in the past.
I didn't much care about it at first either. I found I accidently opened it now and then. After using it for a year I do like it and never open it unless I want the quick access it lends. I would miss the feature but could easily live without it.
