Wyattspoppa
Can someone please tell me the difference between sideloading and rooting? As I understand it, sideloading is simply plugging your phone into your PC via USB and adding apps you have on your PC to your phone's "root" right? Then I use apps2sd to move it to my card (if the app allows). How does this differ from actual "rooting"?
The reason I ask is my Droid X2 keeps crashing on me and this is the 3rd device I've had in a month, first one was due to the bad update, the replacement they sent me was used (lame) and had a damaged power button, this one is crashing due to what I'm certain is an app problem. I'm now loading my apps after scanning with "Lookout" but still having crashing issues, I'd appreciate any input.
Thanks
Thanks
