Ok so I get 0-1 bar at my home and lose service for minutes at a time in 1-2 hour intervals. I've got a few signal boosting apps but they don't seem to help. Ive also looked at some Wilson signal amplifiers but they're expensive and I'm not sure how well they work. Does anyone have luck with a particular app or have insight on the physical amplifiers?
Also my 4g is being nonresponsive and stubborn. When I turn it on it says that the 4g antenna is on, but when I 'tap to check off signal' it does nothing, doesn't tell me it did or did not find 4g signal. Not so much asban "f you" I have boost. I called customer care and they refreshed my phone to no effect.
Also I'm not looking for something magical out of my cdma signal, but a stable 1 bar would be nice. Thanks.
