hi, has anyone had any signal problems or data connection problems with their desires, like no signal for calls or their data connection changing from edge to G all the time?
Yep, I've had that too, if I turn off my wifi and then try and make a call it all I get is call failed, it eventually gets my call through. Another update/fix needed for the Desire :-(
Only issue I have is when leaving my wifi I have to turn my phone off and back on to allow it to look for 3g otherwise it will show phone signal but no 3g. Quite annoying at first but kinda habit now. Logged this with HTC but response was that they have tried their own desire and not had any problem.
Noticed today while waiting around alot that the phone constantly switched between HSDPA and GPRS (never going to 3G?)
I changed my network internet settings to only allow WCDMA and sure enough it held a steady 2-3 bars HSDPA for the remainder of the time I was there. So why did it keep dropping back to GSM when it was enabled?
According to the phone info the preference is set to WCDMA so it doesn't make a lot of sense. Also I would expect it to drop down to 3G before GSM which it never did.
