Root Signal data issues "FIXED"
Krlypumaa
Android Expert
Ok... I have been messing around with issues with band12 lte slow data.
And this its what i have come out with in the past 2 weeks.
Its kind of stupid but by removing HIPRI from apn will make radio to stay on high freq. unless it can not be reached so radio will drop search to lower freq. Then it will search n connect to band12. Feq....
It has been a two intensive test with freq.meters n. QPST & QXDM.
so just delete hipri from apn type? which would leave the apn type as "default,supl,mms"?
is it cool to just do this on the metro apn or should i create a different tmo apn (with tmo settings) and remove the hipri from that apn
If any one want to test if its true just do the changes n dl lte discovery app n reboot your ph & everytime you do open the LteDisc.app n see lock yourself in the closet of house or emergency stairway of building n you will see n probe
I don't see HIPRI anywhere.
are you on tmobile? when i was setting up a tmobile apn on my metro stylo i noticed in the thread that there is no hipri under the apn type...it just says "default,supl,mms" but the default apn type on the metro apn is "default,supl,mms,hipri"
If you are on boost im working with a friend to see how radios connect n disconnect n checking how rmnet-ctrl. routes change... I dont think you guys suffer too much of signal drops.
Thank you for responding. To our fella
oh ok thats it. I use T-Mo's APN but i set it up my self. Still getting shatty data. I think it's this phone. When I had the SG Mega 6.3 I got 100mbp down outside and 50mbp down inside.
People need to make it clear in their tittles what version of the phone they are talking about. Just saying.
Let me tell you its not the ph... After Jun/2015 mpcs n tmo has throttle their data.cap to 20.45 normal.. You can get upto 68-72 depending the area... Now with the band12 data rus between 11-24 cus its not strong enough yet.
https://www.metropcs.com/terms-conditions/network-disclosure.html
