i have htc wildfire s.i have face a prob;em in signal .when i insert a sim in it then the message is appear that your sim card doesn't allow this connection.there is no fault in sim.Please guide me.
Hi sara Azhar. It's great to have join our community. Welcome to Android Forums. The problem may lay in the phone and the sim not sharing the same carrier branding. I'm only guessing. You might want to check into the discussion area we have for your Wildfire S for the best help we can offer. Here is a link to that area: HTC Wildfire S - Android Forums
Best of luck to you and thanks for joining the AF community.
Welcome to the forums Sara Azhar! Glad to have you here
You might want to call your carrier and get another SIM card for your device. Also, if your device was ported from another carrier you might want to double check to see if the 2 carrier's are compatible with one another.
