Has any one noticed that signal quality sucks compared to other devices? My warp and optimus slide had more bars etc then the marquee in my house. Also, is there any reason I should install the system update.
Thanks
The Marquee's signal bars are horrible as far as judging reception. Like mvaness already suggested, About Phone > Status is a much more accurate measurement. Mine is the same way. I'll have full 3G and a -90 or so dbm, but my signal bars will show almost nothing, or maybe 1 bar. An easy way to see this for yourself is to wait until it shows 0 bars, then call your voicemail or something. You'll see your bars shoot up to the correct display (3 bars or so for me), then drop back down to 0 when the call ends. It's something I've noticed since I got the Marquee. Reception is normally still there, even when it shows it's not.I updated my marquee and have 0-1 bar, any tips to increase the reception etc.
Thanks
Going to System Updates and updating your PRL and Profile wouldn't hurt, either.
