Root Signature Verification Failed, Clockwork/Rom Manager HELP
shaahinjjj
Hi all,
I just flashed froyo (I9000xxjpm, 2.6.32.9) on my vibrant which is from Bell in Canada. Everything works fine but when I try to reboot into the recovery using Rom Manager, it reboots and tries to install an update.zip file and then it fails with a message of "signature verification failed". I can't install any other update.zip file either. I'd like to have the clockwork recovery back, any help would be appreciated.
HI, this is because your now running the 3e recovery,
look into the cf-root kernal, this includes root and the 2e recovery.
This will fix it for you.
You will also be able to add a lagfix to your froyo aswell, I myself use this kernal.
[13.10.10][CF-Root v1.2] JPH JPK JP6 JPM JPA - superuser+busybox+2e, CWM compat! - xda-developers
But, along with any flash-there is risk involved, make sure you have the 3 button recovery working at least.
Awesome. I just flashed a kernel that got me the recovery 2e and it worked great. Now all I need is a circle battery with %. I haven't been able to find one for my version of froyo. Thanks anyway
