Silicone Case/Waterproof Arm Band!!
Renniks
Hi all
Looks like I will be buying one of the HTC One X smartphones very soon.
I like to always have my Phones in a Silicone case, and a good one at that!!
Anyone point me in the way of a quality one? Preferably with a tire tread or just plain, and Black please.
Also I would be needing a waterproof arm band for it..
Any pointers are appreciated
Regards
Lee
Hi all
Regards
Lee
Hi Lee,
I read your post looking for a water proof armband that would fit the HTC One X. I spent 2 hours looking so I figured I would post this because this forum topic is at the top of the search list for some reason. The Amphibx Fit Waterproof Armband would be great if it actually fit the HTC One X unfortunately it only supports sizes up to 5.25 inches. On that note, I did find a manufacturer that specializes in water proof gear called overboard. Here is a link to the armband that they have. since you can't post a link in your first post on the forum it is in the post below this one.
