Accessories silicone case with 2150 battery
Do anyone know if the red/black gradient case from Verizon will be compatible with the future HTC 2150 maH extended battery?
i know the battery is slightly larger could the silicone take a little more width on the device?
Do you mean the depth? I don't think the battery grows in width.
I would highly doubt the silicone case will be able to fit the larger battery. I have that case, and its pretty stiff
