sillyrabbitt123
Silly question... does 1GB 3g = 1GB 4g meaning: i have unlimited data on two phones now and i only really use about 3.5gb on each if i go to a shared plan will certain built in apps or are the new 4g phones designed to use a ton more data? Can you get by with the same amount of data on 3g as 4g? i know if i download movies and or skype all the time the answer is no outside of that though?
thanks
thanks
