Help SIM card question
  • Start date Start date
Can you put a HTC one m8 sim into a Samsung Galaxy s6
If you must switch back & forth between the two phones,
DO NOT INSERT A BLANK ADAPTER INTO THE SIM SLOT:
You may get away w/it,with the slide-out tray design,but,I wouldn't chance it:
If the empty adapter hangs-up,you'll more than likely break/damage a contact pin,rendering voice/data inop until repairs are made.
Considering the sealed build design of both devices,JMHO,it's not worth the risk,having a very expensive repair to get up & running again.
