Banankolan
Hi all,
I have a i9300 phone and it has worked all over the world flawlessly. On arriving in Cuba and inserting a Cubacel SIM card in the phone I noticed that the phones wifi stopped working. Inserting another countries SIM and resetting the phone will bring back the wifi.
I found some guys who do all kinds of stuff to the phones and they say it's a common problem here in Cuba. Not only with Samsung phones but with allmost all androids. Apparently some setting on the Cubacel SIM overrides the phones wifi settings causing the wifi to behave wrongly.
After inserting the SIM the wifi will loose contact with any wifi and when scanning for new networks it will only scan for a hundred of a second before giving up and not finding anything.
The guys I mentioned earlier have a solution that works by patching the phone. The problem is that you will loose said patch with every upgrade and I'm in no mood to pay 20$ every time an update to JB comes out to some smart ass who does not want to share the solution with me.
Can any of you folks wrap your head around this problem and give me hints on where to look for a solution? This isn't the normal power saving mode problem, it is 100% related to the SIM card.
My phone is rooted so I can change files and do what needs to be done to the system.
Best wishes,
Banankolan
Best wishes,
Banankolan
