I saw a video for the simi folder app, looks really useful. i installed it on my atrix, but for some reason i am unable to add anything to the folders that i created. Anyone else having this issue, or is it just me, or is it an atrix thing?
are you sure you're using it right? you have to launch the app itself to manage folder contents. in other words, you can't add stuff from the homescreen as far as i know.
super awesome app. the only issue i've been having is that there is sometimes noticeable lag when launching apps within the folders (whereas launching apps from the app tray is instant). anyone else experiencing this as well?
I have an atrix and I have the same issue. I load the app, create the folder but when I try add the apps and it says nodata. I can load contacts no problem but not the apps. Does anyone know how to fix this?
