Simple audio player recommendations
I have a collection of audio files (FLAC format) and I'm looking for an audio player that makes it really easy to select and play ONE FILE. I don't care about playlists, EQ settings, reviews, pulling suggestions of related things from Spotify or other sites ... none of that stuff. I just want to be able to point to one file and play it and stop when it's done, without having it just going on to the next file and the next and the next.
There seems to be hundreds of players in the Play Store and they're all tripping over themselves to offer more and more features that I don't want. But every one I've looked at makes it incredibly difficult if not nearly impossible to simple select one sound file, play it, and stop playing when it reaches the end.
Here are the key requirements, in case it's not clear:
* I don't want to have to create a playlist first; just select a single sound file and hit play. (Literally, 2 taps.)
* when the file is done playing, I simply want it to stop playing and not magically find something else to play automatically.
* in case it matters, these files play for 20-30 minutes. They aren't jingles or ringtones.
Suggestions?
