Root Simple Modifications
ZeroGeined
I'm just playing around with my phone trying to really make it mine, if you know what I mean, and I was wondering, does anybody have an overall directory for this phone or know where to find one? I've already discovered where to find a few of the system sounds such as the camera shutter and lock sounds and the stock startup.bmp.
Where did you find the stock startup image. Is it the metro pcs splash screen? I.he been wanting to change that since I got the phone.
Also, i used rom toolbox pro to change my system fonts And my bootscreen animation.
same here. changed my boot screen but fonts didn't seem to work.
I was having a problem with one of the boot screens, it just left my screen black until my phone booted up. Kinda scared me for a min (I thought I soft bricked). But since then I've installed a few boot screens. I've only installed one font so far and it worked for me.
I also have an app called framework tool that can do some pretty cool things. I've been warned about this app and nothing bad has ever happened.
Still, use at your own risk
I haven't found the metro animation, just logo.bmp in the root of the phone.
I don't know what that Logo.BMP is but when I change it, nothing happens. It also looks like its a different color than the splash screen. So I don't think its the splash screen.
Also this app called framework tool is amazing. You can change a lot of different things on your phone, like the way you transition into apps. I also changed the system background. Check out these screen shots.
