Root Simple nandroid vs. advanced?
shadowdude777
Android Expert
Hey you guys, what are the settings that you get when you do the Simple Nandroid Restore? I'd like to keep a bunch of Nandroids on my SD card so I can switch it up as often as I want, but the only way to choose the Nandroid you use is with advanced and I don't know which folders you're supposed to choose to restore (like SYSTEM, DATA, MISC, etc.). Can anyone tell me how to do this so I can keep a bunch of Nandroids on the SD card and get the same effects as if I had done a Simple Nandroid Restore with that backup? Thanks in advance.
