what phone do you have? usually you can tap the place where you want the cursor to be and then backspace the character you want deleted.....that is how it works on my note 10+ 5G.When I'm texting, I know how to backspace over previous characters, but how does one place the cursor and use delete like on a computer KB? I've never found "delete" on my LG6...
Thanks!
Russ
what keyboard are you using? if it comes with the phone, maybe try a keyboard app like Gboard-the Google KeyboardLG -G6. I don't have a backspace key that I know of...
Russ
1. Long press on the text you'd like to delete.
2. Release your finger.
3. Options will appear of what to do.
You can also drag the "text select postions" after step one to refine your selection.
