Willie Heckerslyke
Member
Hi all
I've made the step from Setting Profiles to Tasker and it's a steep learning curve to say the least!
For my first basic attempt, I've just set it to have wifi + 3G always off unless I load up a net-based app like FB, Twidroid etc...and it works....sort of
- the two start up ok when I want net access but it's afterwards I'm struggling with.
I've put an exit task to switch them back off when closing the app - which it does - but I'd like to put a delay on it so that it switches off when I turn off the screen, not when I close the app ( I might want to run another app straight after, that also requires wifi/3G, but at the moment, the second I exit the app, wifi/3G turns off.... )
I asume it's done with the 'if' option but when I select 'screen' in the left hand box and then 'matches' in the middle 'condition operator', there's no 'OFF' option in the right hand side box.....
I'm obviously doing something fundamentally wrong here....can someone help me out?
Thanks for any help....
Edit: Found a work-around by having another profile that stipulates, screen off> wifi/3G off. I couldn't see how to just have the exit task pause the execution of net access off via screen-off
