plzzzzz help, i have installerd six guns on my gt S6102 , and used chainfire also , but when i start the game it force closes.I tried wit TECHNODUOS but still it force closes.plzzzzz help
Hi TaZo. Welcome to Android Forums. You might try uninstalling the app and then reinstall. Perhaps the install had a problem. You might also check your resources.
You might have a lot of background usage limiting the necessary resources to run your game. Good luck.
