greg schmeg
Guest
Anybody know about using the app PS3 Pairing Tool to change the Bluetooth code inside a six axis controller to sync with or android? I have an S2 running baked blackbean.
I have seen videos on YouTube of some people using the actual SixAxis Controller application to pair the controller, but apparently this method doesn't work for most. Didnt work for me either. At this point you can either use a USB on the go cable and use the paid app inside the play store PS3 Pairing Tool and pair the Bluetooth addresses that way, or you can use SixAxis Pair Tool on a windows PC , available at dancingpixelstudios.com to change the controllers master Bluetooth address. I have the on the go OTG cable and I have all the paid for apps, including ps3 pairing tool. I have seen on YouTube people pairing their controllers with the ps3 pairing tool app. I CANNOT GET IT TO WORK FOR ME. I don't have a PC so I have to bug someone to let me use theirs if I can't make it work with the paid app that I have that's designed to accomplish the same thing the PC accomplishes. Soo... I would really like to accomplish pairing my ps3 controller to my s2 without using a PC. Any advice as to what I may be doing wrong? Is my rom incompatible? Thx in advance.
