Skype For 3G
chrismgan
Member
Is anyone using the Skype modified app that allows you to call over the data network? I was wondering how it's working for others. Mine has been horrible as far as call quality- almost unusable. I'm on 3G. I was wondering if there were any settings that needed to be enabled or unenabled? My Skype wifi works great. Would love to hear some reports.
Are you on Verizon? If so, any calls made in the US to US numbers uses the verizon network. Calls made internationally will use 3G, and if you are in an area with slow 3G/poor latency, calls will sound pretty bad.
