saladdodger
I've installed Skype on my Xoom (Honeycomb 3.1) but it doesn't regognise the mic. The bottom LH icon shows a disabled black mic or, when pressed, a disabled blue mic.
The mic is working with other apps. I've only just got the device so I'm inexperienced with it's quirks. Is there a setting that I've missed? Is there another app that I need to remove as it conflicts with Skype? I'd prefer to use Skype possible as I use it to make calls to mobiles when abroad but I'd consider anything that works on the Xoom.
BTW I'd like to use the integrated mic rather than separate Bluetooth or wired headphones.
TIA - SD
TIA - SD
