Sleep Mode Too Soon
saptech
Android Expert
Hello all. I finally got a Nexus 5X (today) but haven't switched carrier to it yet. I am able to use it with wifi. Right now my concern is the screen will go in 'sleep mode' too soon, like a few seconds if I'm not using the phone or if I pause from what I'm doing. I set the Sleep setting to 2 minutes & Screensaver is off. How can I stop this?
Thanks.
Yes, been there, done that. It doesn't make a difference. I sent it back to the seller and he's looking into it.
Thnx.
I figured out the issue. It seems if I copy from my old phone, Apps & Data using Bluetooth, is when the Timeout issue occurred. After starting the N5X with new setup, the timeout issue does NOT occur. I guess it's a bug with the Nexus or my zMax Pro phone.
Surprise nobody else has ran across this problem!
Thanks.
