slide settings
problemmj
hi there.. i got a new xperia x10 but on the unlock screen jus before u put the pattern to unlock. instead of the slide up i am getting this normal slide like i phone. can ne1 help me change it to the slide up! i tried everthing!
Hi There
Welcome to the forum
The X10 has never had a slide UP to unlock and the iPhone style of sliding across is the only one available
hope this helps
(unless you meant the arc to unlock - which has now been removed)
thanks. u know the lock screen where you see a curve which says slide here.. thats what i am talkin about..is it arc u were talkin about? i really like that screen. please help!
on 2.1 you can still use the arc movement to unlock as long as you touch the left bottom corner and then swipe towards the middle right
ric
thanks alot ric and the other user.. i downgraded my fone jus for that slide!! :P thanks alot for ur hep guys!
LockBot Pro from the Android Market could have given you this back too.....and then you'd still be on the most recent Android version available from SE.
