Hi guys, 1st post, the Coby Kyros i have will not open . It turns on, the time screen shows but when I go to move the slide to open the pad it will not move no matter what I have tried.
1. Are you routed and do you have a custom recovery installed?
2. Are you using a custom lockscreen app?
3. What did you do (ie installed apps, custom edits to /system files etc...)
D. Did you drop it before the issue occurred.
If....
1= no then go to 2. (Also Google ktz the kyros tablet zone and get a recovery next time.
1= yes then boot into recovery and try a factory reset or restore a good backup
2= yes then boot into recovery (stock is OK) and select factory reset
2= no then go to 3
3= deleted systemui odex or any /system folders then go to the kyros tablet zone and flash a recovery and a working rom
3= installed an app w/o looking at permissions or similar then go to "2=yes"
D= yes then D= you broke it (if you are inclined then you can pop it open and look for loose connectors on the screen)
