Slide to unlock/answer
I am currently using a slide to answer that goes up and down. I would like to change that to a slide to unlock/answer that goes from left to right. When Someone calls and I get the phone out of my pocket, the screen will touch my pocket and auto answer/drop the call.
Is there an app that will change it from up/down to left-right?
Try to check out caller ID apps in the market. Some have options for changing the answer call method. I haven't used one for some time, but you could check out the free version for Full Screen Caller ID, I remember it had a way to change the answer method in its settings.
