Help Slingbox users with a One X
olsonn
Does the black Menu bar/button show up when you're watching something via SlingPlayer Mobile, or is that App up to date with the Ice Cream Sandwich specifications?
It would be annoying if some of the screen is taken up by the Menu bar/button.
Thanks for any information you can provide!
One more try here...
There's gotta be someone that has used their Slingbox with their new One X, especially now that it's out in America. Right?...
Help a brother out! Thanks in advance.
Hi,
I have the AT&T version of the HTC One X and Slingplayer works great on this thing!!! The picture fills up the screen except the right side does have a very small vertical black bar with three dots (this may be the "menu/bar button" that you are referring to) for opening up the options that can be selected for things such as guide, dvr, aspect...etc. Hope that helps...
Hi,
Denise,
That's exactly what I was wondering. Thanks for the response! Sling Media needs to update the application to be Android 4.0 compatible, and that menu bar will disappear and we'll get more screen space for the "TV" picture.
Denise,
You're welcome... That would make it even nicer!!!
