When I pull the S Pen from my Edge it's taking about five seconds for the note taking app to appear. Is this normal? That's a long time with no indication of anything happening. In general I find moving around inside the S Pen notes application to be very slow.
I am having no problems with mine - not sure why you would. Are you on Lollipop yet? Or still on old software. You might just try rebooting - pop the battery - or check on you-tube. There are some tips and tricks to speed up the Edge that I have done and mine works pretty quickly. Just a few thoughts - hope one helps.
