Help Slow charging through USB?
youngdoc
I drained my TB down to zero not long after getting it today (installations, sync, etc.) and I currently have had it connected to my PC via USB for several hours. Charging seems to be incredibly slow -- I am only at 50% at the moment. It is set at "charge only" in the USB settings, incidentally, as opposed to "disk drive," etc.
I switched it to the wall charger for a bit and it seemed to charge a bit more quickly there, though I haven't analyzed it closely yet.
I never noticed this effect with my Incredible and I'm using the same USB cable and the same power cord. Anyone else notice this?
Depends on the PC.
Wall charger provides 1 A as previously stated; my USB port is providing 500 mA, works fine.
Some USB ports go _much_ lower, not all are full-power ports. On many PCs, if the one charging very slow is on the front of the chassis, you'll probably find that charging from a rear USB port is much better.
Another tip would be to look for a USB port that not only has a USB symbol, but also "SATA" or a lightning bolt symbol on it. They are most likely to supply power to the USB device.
