TheNewZackMorris
For the past couple weeks I've had the problem of the phone taking a long time to turn off. This started shortly after installing the 2.1 update. Tonight I turned the phone off and nearly ten minutes later I finally heard the shutdown sound. Sometimes it takes 3 minutes, sometimes later. I have found that if I don't hear the shutdown sound I can press the power button and the screen will come back on then it will shutdown.
Is anyone else having this problem? I'm not really sure what would be causing this problem because I've checked it before and haven't had any extra running services other than the keyboard and voice input services when it was turning off.
Thanks for any help you all may be able to give.
