I'm experiencing an annoying bug frequently with smart actions on both of our razrs. We have a smart action defined to turn off cellular data when connected to wifi at home or work to save battery. That part seems to work fine and makes a considerable difference on battery. The problem is that frequently, data doesn't get turned back on when I leave wifi coverage. Manually ticking the box fixes the problem each time.
I made a comment in another thread where I (and others) are experiencing wifi dropping frequently and I'm guessing that this is the cause as I'll have wifi drop and come back very frequently while at home and the smart action will keep going back and forth. I'm guessing that something is getting lost among the constant cycling that forgets to reenable the data.
Is anyone experiencing anything similar or have any suggested fixes?
Thanks,
Thanks,
Gotta turn off the action for data to come back right away.
