BigRedGonzo
Android Expert
I have a Bionic. I usually use Setting Profiles, but I wanted to give Smart Actions a try. (I am always messing with something.) I am wondering if someone that uses Smart Actions can give me some help. I have three questions for now.
1. I am a Chemical Engineer for a manufacturing company and am on call 24/7. At night I want to set the phone to silent for everything except ringtone and I want to set the ringtone to about 50% volume. Is there a way in Smart Actions to accomplish this. I found the volume setting, but cannot determine how to get silent mode with notifications and 50% volume with the ringtone.
2. I have a trigger to turn on WiFi when I am at home. I have a second rule that turns on WiFi when I am at work. I have two rules because I cannot figure out how to set two locations with an "or" relationship in one rule. Is this possible?
3. When you set a set of actions based on a trigger, when the conditions of the trigger no longer apply, does Smart Actions set the changed conditions back to their original value? An example, I have a rule that sets the phone to silent during a meeting. Let's say a meeting runs from 1:30 pm to 2:30 pm. At 1:30, the phone's volume settings go to vibrate only. At 2:30, does it return the settings back to where they were prior to changing them at 1:30? I am assuming it does, but I have seen some where you had to undo the rule and it was honestly a PITA.
Any help will be greatly appreciated,
BigRedGonzo
BigRedGonzo
