Help Smart actions
I would like to set my phone so I can silence all calls except a couple numbers when I am sleeping. I am on call an can be sleeping about any time of the day. Is this possible?
You "found" an app for that? Your headline indicated to me you were asking about Smart Actions which is an app already on your phone. Of course, there are other apps available that are similar, and some consider better than SA, but why did you ask about SA if you had to go find an app?
I made a mistake. I should of asked (just a way to do it) and not asked about Smart Actions. I was trying to do it with the smart actions because that was on the phone. I apologize for not being clear on what I was looking for.
Thank You Sir for your time.
Byron
Was just confused, but as long as you got what you wanted, all is good. I use Smart Actions to do what you indicated along with a host of other Smart Actions.
