Smart Keyboard Pro Issue
Harreem
Hey guys, so I'm having a problem with Smart Keyboard Pro's T9 setting on my Xperia.
When I type in a word, with T9 enabled, it does not automatically replace the letters I type.
For instance, if I type the keys which have the letters for the word 'Hello', it would end up as 'Gdjjm' until I press space, as it auto-selects the most viable word.
In most T9 keyboards, the letters in the suggestion change as you type, to give you a better idea of what you are typing, although my Smart Keyboard Pro does not.
Is this a bug or just me ?
Thanks.
Thanks.
Hey, 5 years down the line, I have the same problem as just downloaded the app today. Did you manage to fix it?
