Having a weird problem with Lollipop's Smart Lock that I can;t seem to find any answer to. Hopefully someone will have some suggestions.
I set up the phone's security and it works fine. Then I set up a smart lock trusted place/device (same scenario happens with both). Put the phone to sleep and wake up and the smart lock seems to work -- I have to only swipe up to get to the homescreen (no password required). But from then on the security is basically disabled altogether. The next time I wake the phone I no longer have to swipe up the lockscreen -- it just goes straight to the homescreen. If I leave the trusted place/device the phone also just goes straight to the homescreen. When I return to the trusted place/device, same thing. I've done this with bluetooth device and with GPS in all settings.
So essentially the smart lock feature is disabling security altogether after the first "smart" unlock. The only way to get security working again is to go back and set it up all over again (enter new pattern/pin). I'm running Google Play Services v7.5.71, which I assume is recent enough to avoid the previous smart lock bug.
Any ideas?
Any ideas?
