Smart Phone RAM
Hi :hello: welcome to the forums! unfortunately there is no way to physically put more ram into your phone. there is however apps out there to clear your ram so you have more free. some do more harm than good tho. if you want a good app to close out of background apps then try out SystemPanelLite Task Manager. hope this helps!
which phone are you having problems with anyways?
Welcome aboard.
Thanks for stopping in to join us. Hopefully you'll find our resources helpful. :)
