Smart Scroll missing?
Are you referring to the Gallery where it is called Slideshow?
It shows up in the 3 dots menu on my Verizon phone.
IF though the picture has displayed a few seconds, the 3 dots disappear. You can bring the menu up again by long hold depress on the Double Menu outline.
If you mean scrolling text, I have not done that yet.
It's supposed to detect your eye movement for reading documents and pages and automatically scroll. A friend said that his S4 had the feature, I couldn't believe it so I wanted to try it. There is so much stuff on this phone, I am blown away, my first Samsung phone, had nothing but HTC's before the S5.
http://m.youtube.com/watch?v=fKwL6hp7fn8
I believe that was removed with the S5. They've cut down on some of the frivolous apps this time around.
I read somewhere where Smart Scroll for reading text is still on the S5, but a search does not find it on the Setup Menu... hmmmm
The S4 has it
http://www.talkandroid.com/guides/s...e-and-smart-scroll-on-the-samsung-galaxy-s-4/
This article says they are still there:
http://www.engadget.com/2014/04/11/samsung-galaxy-s5-review/
Older Samsung features like Air browse, Air view, Smart stay, Smart scroll and Smart rotation are all still here, though they aren't quite as in-your-face as they once were. In fact, most of them are buried in the settings, so you have to want them in order to find them. Safety Assistance, Blocking Mode and Easy Mode are also around.
The S4 has it
How to set up and use Smart Pause and Smart Scroll on the Samsung Galaxy S 4 | TalkAndroid.com
Samsung Galaxy S5 review: a solid improvement, but don't rush to upgrade
I looked for it, couldn't find it. Still getting used to the motion features.
I'm sure I will never use the smart scroll, I just wanted to see how it works.
SMART SCROLL on the S5
Settings➡accessibility➡dexterity and interation
I just looked at that menu. On the standard Verizon subscribers version, there is No Mention at all of Scroll.
I think that it was left off and is not available.
This is sprint version
Don't be too upset. I have it on my Galaxy Note 10.1 2014 Edition. After giving it a try, more than once, I turned it off. It was too sensitive at times and not enough at other times.
Well damn, I learned something new today!! Did not know the same phones from 2 different carriers will have different features. Soooo.........I'm guessing every carrier tells Google what features they want on the O/S for their phones along with the standard list of bloatware?
I would say yes since some carriers blocked the wifi/lte dual download which was supposed to be a feature to download stuff alot quicker
Very easy to find smart scroll..touch the settings icon at the top by the search icon type in smart scroll. It will take you right to it!!!
I love mine!!
I love mine!!
Maybe on yours, but it won't on a VZW S5.
The following is from the Samsung 270 page Users Manual, but I can verify that none of this exists on a Verizon phone.
Using the smart scroll feature
Set the device to scroll the screen up or down by tilting your head or the device. You can use this feature while viewing emails or webpages.
On the Apps screen,
tap Settings → Accessibility → Dexterity and interaction → Smart scroll, and then drag the Smart scroll switch to the right.
Use the following options:
