Root Smart share for LG connect
TonyConvict
Member
Can anyone get the stock smart share app for this phone.... that was one feature I love using but I only have the LG esteems smart share app and it tells me manufacture mismatch... could it be telling me that cause I changed the build.prop to Samsung nexus?
That seems entirely likely the case, however, if the galaxy nexus has a smartshare app, you could probably get ahold of it from their forums and run it that way
Here is the stock one for the connect-place in system/app folder-reboot or install after download.
https://www.box.com/s/0ef21834cce3905cc9c2
Why did you change the build prop to a Samsung Nexus BTW:confused:
Moving this to the root side-FYI:)
I changed the build.prop to nexus so I can play unsupported games... I now have modern combat 2 & 3, Nova 2 & 3, Max Payne, Mass Effect, the Sims.... and may I say graphics are wonderful on this beast of a machine
Is there any way the apk file can be modified so it can be used by any brand phone? Such as maybe bypassing the manufacturer check or something?
