Smart Viewer.
biledigger
Anybody know as to why smart viewer can be turned on and off on our devices but not triggered by the long pressing of the back key?
there are several apps with that name, which one are you talking about.
give us a PlayStore link
Its built into your device. Use an app launcher to find it. It provides you with a popup shortcut menu to run apps within either windowed or fullscreen mode. I just cant get it to activate for some odd reason.
what phone model you talking about?
not all phones have the same builtin apps
metropcs. I used an app activity launcher and targeted the system settings apk. There is an activity called smart viewer inside. Holo launcher can open it as well.
Hi. I installed both holo launcher and app activity launcher and have not seen smart viewer. I am interested on this can you just post a guide and how you run smart viewer using those apps? I uninstalled them already coz I don't even know how to use them.
I used holo launcher to access activities. Then opened up a sub activity in the settings apk for smart viewer.
Long press on your desktop and select shortcuts. Then select activities. Now scroll down to settings. Touch settings to expand the options list. Now scroll down to Smart Viewer and open it.
Hi thanks I just installed holo launcher again but I only get widget, setting and wall paper when I Long press on desktop. Can you link the holo launcher you have?
This is the one I installed. I think coz sometimes they have different links from phone and PC:
https://play.google.com/store/apps/details?id=com.mobint.hololauncher&hl=en
Nice. Thanks. Finally found it. I turned on smart viewer and long press back button like it said on tutorial didn't do it for me too. Nice find. I don't think I will keep it though coz the permission for me to install this holo launcher is scary. LOL.
Did you turn it on? There is a slider. So you actually can't use it right? I slide it on and long press back button but nothing happen. Most likely the driver/component for it to run as it should is not installed. It usually is the case.
