Smart window
V
Valiceemo
Guest
Just wondering if there are any apps or widgets compatible with the smart window case.
For some reason I have deleted the analogue clock widget that came pre-installed so now I can't have the clock with the cover closed?!
Bump.
Any ideas on how to get the widget / app back for the clock?
factory reset ?
if you rooted and deleted the app you may need to download the Stock rom for your device and reflash
you may also be able to find somebody who uploaded all the stock apps online somewhere as well.. search XDA, I'm sure even with all the different G2 models the clock app is somewhat the same for all.
Don't know how that might happen with a widget.... however with an app, if you go into settings and then applications manager you can disable certain apps. When you do that they become "hidden" unless you reverse the process and enable them.
If you haven't rooted and haven't uninstalled something that was there stock, then possibly something related was disabled.
